Old 02-07-2016, 03:41 AM   #424 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Is the Tinkerkit LCD code broken? When I try to compile for the leonardo, I get a compile error on Ardunio 1.6.6.
Code:
Arduino: 1.6.6 (Windows 7), Board: "Arduino Leonardo"
C:\Users\H-man\Documents\Arduino\sketch_feb07a\sketch_feb07a.ino: In function 'void USART_UDRE_vect()':
C:\Users\H-man\Documents\Arduino\sketch_feb07a\sketch_feb07a.ino:4219:6: warning: 'USART_UDRE_vect' appears to be a misspelled signal handler [enabled by default]
C:\Users\H-man\Documents\Arduino\sketch_feb07a\sketch_feb07a.ino: In function 'void serialTransmitEnable()':
sketch_feb07a:6489: error: 'UCSR0B' was not declared in this scope
sketch_feb07a:6489: error: 'TXEN0' was not declared in this scope
sketch_feb07a:6489: error: 'UDRIE0' was not declared in this scope
C:\Users\H-man\Documents\Arduino\sketch_feb07a\sketch_feb07a.ino: In function 'void serialTransmitDisable()':
sketch_feb07a:6496: error: 'UCSR0B' was not declared in this scope
C:\Users\H-man\Documents\Arduino\sketch_feb07a\sketch_feb07a.ino: In function 'void serialTransmitByte(uint8_t)':
sketch_feb07a:6503: error: 'UDR0' was not declared in this scope
C:\Users\H-man\Documents\Arduino\sketch_feb07a\sketch_feb07a.ino: In function 'int main()':
sketch_feb07a:8544: error: 'UBRR0H' was not declared in this scope
   UCSR0A &= ~(1 << U2X0);
sketch_feb07a:8545: error: 'UBRR0L' was not declared in this scope
   UCSR0B = 0; // disable serial uart pins
sketch_feb07a:8546: error: 'UCSR0A' was not declared in this scope
   UCSR0C = (1 << UCSZ01)| (1 << UCSZ00); // set for 8 data bits, no parity, and 1 stop bit
sketch_feb07a:8546: error: 'U2X0' was not declared in this scope
sketch_feb07a:8547: error: 'UCSR0B' was not declared in this scope
 #ifdef useBufferedSerialPort
sketch_feb07a:8548: error: 'UCSR0C' was not declared in this scope
   serialBuffer.init();
sketch_feb07a:8548: error: 'UCSZ01' was not declared in this scope
sketch_feb07a:8548: error: 'UCSZ00' was not declared in this scope
exit status 1
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
