Old 02-07-2016, 05:58 AM   #15 (permalink)
RedDevil
90 day: 57.12 mpg (US)
One problem with the harvesting turbine on intake would be a drop in intake air temp.
If you draw a vacuum the temperature drops. Some of the heat loss is overcome by the friction, but if you take that away with a turbine then the air temp would drop more - quite some in fact. This may reduce the combustion efficiency.
Would be good combined with a WAI though
