Old 02-08-2016, 11:43 AM   #428 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
I have no problem in helping develop the code, it will just be slow while I work on my BS in EE.
The trick I used was to get away from the MPGuino code was to flash a new sketch with nothing in it since I could flash that in the 7 second window you get before the code loads.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
