Originally Posted by dremd
https://www.hornblasters.com/product...ker-2-air-horn
Is what I run. it is genuinely at least as loud as the horns on trains (I live 1/3 mile from a major rail line) and FAR louder than most 18 wheeler horns. I have a 1 gallon tank and a Via Air 450C compressor. I get about 1.5 seconds of FULL ON BLAST, followed by about 3 seconds of honk before I'm totally out. In virtually every case I've been in a 1/2 second BLAST is ridiculously to long, and you feel like you have over done it. Seriously, with great honking power comes great responsibility, you have to judge what all of the cars around you will do when suddenly there is a train in the middle of the road.
If you want one, TOTALLY get one, I'm not trying to talk you out of it, I just want you to realize what you are getting yourself in to.
Sounds ..
.. like I should leave my existing horn and add another button for the choo choo horn!
I read somewhere .. no luck with a quick search .. about a product that uses your normal horn for the first 1/2 second and kicks in a louder horn after the time delay. That would remove the extra wiring and make it easily accessible from the single horn switch ...
