Old 02-09-2016, 04:19 PM   #430 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Oh, good.
Got some other good news. Apparently did not brick my ICSP programmer, after all. Also managed to re-load the TinkerKit LCD bootloader into the module, so I could program it again with just the USB cable. However, once I loaded the TinkerKit LCD with the new MPGuino code, it stopped accepting any other attempts to load the code using just the USB cable. This is kind of a big deal, with regard to future upgrades.
I am also having a problem with adding the expansion pins to the TinkerKit LCD module. When I compile the new code for the Tinkerkit LCD without support for expansion pins, it lights up the LCD display just fine. However, enabling the expansion pin support causes the LCD lights to not work. Still working on that.
