Old 02-11-2016, 08:57 PM   #60 (permalink)
Vajra
Okay, now it all makes sense. I have to wonder though, with the back end being like T Vago's, wouldn't that be less aerodynamic than just terminating at the tailgate? While I can see air moving and transitioning more smoothly along the top/sides, I would suspect that the tail end would not have much less drag verses a tail end that ended like a aerolid such as Bondos, or Swede's. I understand the concept of CL verses CD, but I have a hard time seeing how air flow being smoothed out would have a greater effect on efficiency. Or... Are we talking about having the back at 7-8" off the tailgate, with a similar curvature for the tail end? If I was do to what T Vago is doing, I would use foam as well, bread and butter style vertical sections. Don't think ply wood would be so easy to deal with in the larger lumber sizes. If 1/8" inch, sure... not 1/2" though. I think I would want slightly rounder edges and a flatter center though. My thinking, the edges on T Vago's tail end, would have a not so smooth arcing action of air on the sharper corners. Or am I mistaken? I am NOT knocking T Vagos work in progress, that cap looks very nice. I just don't see how it would be benefit reducing the CD as much as other options. I will never go out further than the tailgate down. As my truck is a 2500 4x4 with 4:10 gears, I don't see a possibility of much over 2mpg max with the aero cap. If I do, I think it would be to the point of losing much of the useful area of the bed. If I had to open it to carry cargo, what would the effect of the rather round end be if open say 1.5 feet? I suspect because of the shape, shallow corners, I'd end up having to open further up to accommodate a similar load. Hmmm... And yes... I want to hone in on a optimal shape, but also, most useful design possible. Construction wise, I think I can do just about anything one the design part is done.... at least I think so...
The Following User Says Thank You to Vajra For This Useful Post:
aerohead (02-12-2016)
