Old 02-12-2016, 07:50 AM   #52 (permalink)
Astro
Dreamer
Originally Posted by BLSTIC View Post
...Existing temperature controls would remain in most cases even with the ceramic core
Yes, as the air flow increases the ceramic element will cool which causes more current to flow and the element will return to its equilibrium temperature. The higher the air flow the higher the current flow to maintain the temperature but it is all automatic.
It does seem like the simplest, cheapest, best performing solution.
It also makes a nice test load for the batteries as it is working at full pack voltage and is simple to control.
