Old 02-13-2016, 05:55 AM   #111 (permalink)
Shawn D.
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
I was already backing away from the flow bench. What sensor would you say are used on the dyno. A high-speed recording manometer? Microphones?
The only sensors regularly used during dyno testing are exhaust gas temperature (EGT) and air-to-fuel ratio (AFR), to ensure proper running, not to determine flow. Vacuum is also measured, but to determine "streetability" of a combination, signal to the carburetor or sensors, or if portions of the intake tract are a restriction, but again it's not to determine flow. In any case, the point dyno testing is to determine actual running effects via the resulting calculated torque and horsepower.
I did this to illustrate the end-cuts I proposed. The collector would have three tabs. Convergent angle is not represented. This is thirds of a Christmas wrapping core, not what you were thinking.
That's a goilet, as has been pictured and discussed before in this thread.
What is the relationship between scavenging and anti-reversion. It seems they are at cross purposes.
They are not at cross-purposes. Scavenging is to help ensure the exhaust gases are pulled from the cylinder and anti-reversion is to help ensure the exhaust gases are not pushed back into the cylinder by pressure waves or flow from that cylinder or others.
What if its too efficient and vacuums out the cylinder causing more air and fuel to be pulled in?
Originally Posted by RobertISaar View Post
possibility, generally one would design a cam around it with a tiny amount of overlap
Yep, this does happen at higher speeds and excessive overlap is a primary culprit (and at low speeds, the same physical configuration will usually cause some backwards flow into the intake tract). Not only will over-scavenging hurt power and efficiency, the unburnt gases will cause problems with the sensed AFR. One might think this would be sensed as a rich mixture, but due to the excessive oxygen, it is sensed as a lean mixture, causing the ECU to add more fuel.
The Following User Says Thank You to Shawn D. For This Useful Post:
freebeard (02-13-2016)
