Old 02-16-2016, 03:47 PM   #1 (permalink)
broski499
Boltar - '19 Chevy Bolt LT
2008 Prius Air Dam
Hey guys, what have you used in the past to create an air dam in the front of the prius? What did you use to attached it to the front. Also I know many have used different methods to create a grill block. What have you found work best? Want to actually start adding some modifications to Padme. Prob going to remove the rear wiper too, it hardly does anything as is.
