I would try to put the weight divided between the trunk and the under hood area . If I had to / needed to , I would put more weight in the rear . Too much weight in the front is possibly going to cause problems . If stronger springs are needed , I would think it would be simpler in the back .
Be careful what you do in the front . You do not want to mess up the front suspension and / or allignment .
God bless
Wyr
