Old 02-19-2016, 02:47 PM   #21 (permalink)
oil pan 4
As you said, one of the best ways to burn up smoke is install a turbo or turn up the boost slightly.
In my 6.5L diesels short life as a non-turbo it did smoke a little bit, then after I put the first turbo on that got rid of nearly all the smoke and improved fuel economy 2 to 2.5 mpg or by almost 10%.
To further reduce smoke production and engine oil consumption on my 6.5L I machined the heads so I could put actual seals on all the valve stems. The intake valves had something that barely resembled or functioned as a seal and the exhaust valves had nothing.
I didn't have to do it but I did.
