Old 02-19-2016, 03:52 PM   #22 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
If there is a DPF doing its thing near you it is producing colorless odorless diesel particulate in the 1 to 2 micron range it defeats all your body's senses and defenses. And you unknowingly breath the particulate deeply into your lungs.
The DPF does eliminate most of the diesel particulate but what it does produce is exceptionally bad for you.
With a non emissions controlled diesel the particulate is big, from 20 to 250 micron is what I am hearing. You see it you smell it and react to it you don't breath it in, unless you really like the smell of burned diesel.
So non-controlled diesels create only large particulates and controlled diesels only create small particulates?
Or...
Non-controlled diesels create all sizes of particulates, while controlled diesels filter out most of the large particulates?
If the latter, then do non-controlled diesels create less, more, or the same amount of the small particulates as controlled diesels?
Originally Posted by RustyLugNut View Post
Diesel and gas engine controls will become more alike as time goes by.
Diesel and gas engines will become more alike as time goes by.
