Old 02-19-2016, 09:20 PM   #21 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by Andrei_ierdnA View Post
I have a suggestion if you cannot get to the bottom of this dilemma:
* sell your large 1kW block heater and with that money buy a small block heater 125-250 W.
So instead of heating your coolant in 20 min and having a localized boiling point, you will have to plug into a timer and let it heat the coolant for several hours overnight. Same end result, same electricity cost, but with a lower and more gradual heating of the coolant and without any localized boiling.
Just an fyi to the OP and anyone else curious. I have an OEM 400w heater in my car on a timer that turns on at midnight and off at 6:30. I park in an uninsulated and unheated garage and the car is between 85 and 100 degrees when i leave. Within 2 minutes of cranking and 1 mile down the road it will be about 150 to 160. If the temps drop to around 0°F, it only gets to around 140 in that time.
