Cold to a point hot toa nother point
https://www.google.com/url?sa=t&sour...p7benxIxptTjGQ
What I get from article
If intake or under hood intake air temperature is 75 º F at atmospheric pressure (14.7psi @ sea level) the turbo outlet temperature will be 285 º F at 20-psi boost. And the IC should drop that to about125f-100f @the valves
90f or higher IAT = loss of power @1%per10°f and fuel efficiency eg:
A 250-HP engine will develop only 240-HP if the air temperature is 130F (54C)
using the same quantity of fuel. Less work more fuel
Cummins retained the 160hp rating on pre91.5 with larger injectors 4x.012" water to air cooler. Vs 91.5-93 got 6x.009" and the air to air intercooler smaller injectors less boost with the same 160hp is a good factory example what happens when you go cold air
1st gen pre 91.5 has the water jacket intercooler that works with newer 12valve and maby 24valve heads. Blockheater is able to heat intake air@ plug in with coolent.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
![](http://ecomodder.com/forum/fe-graphs/sig8842a.png)
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
