Old 02-22-2016, 02:36 PM   #128 (permalink)
freebeard
If the rear window is non-opening, then the thickness is probably Okay.
Why don't you route a 1/4x1/2" ledge in the edge of the foam? And my folks used to use sheet Mylar plastic and squeegee the resin out under it. It doesn't stick (maybe test first) and when you peel it off you get a smooth, even glossy, finish.
aardvarcus (02-23-2016)
