Old 02-25-2016, 01:22 AM   #352 (permalink)
e*clipse
Permanent Apprentice
This is a follow up about the rotor test.
I placed a piece of iron ( the MGR's counterweight ) near the rotor. If you rotate the rotor while holding the iron near it, there are 8 evenly distributed distinctive places of magnetic attraction. This is a very strong attraction - it can really hurt that finger that is between the iron and the rotor...
I also tested the rotor with a small magnet. This is one of those magnets used to retrieve parts you drop when working on your car.
The result were quite different - about 12 non-evenly distributed attraction places. This is probably due to the v-shaped arrangement of the magnets in addition to the magnet's polarity; I'm not sure.
I'm not sure if this helps; it certainly makes it difficult to visualize the rotor's alignment with a magnetic field.
E*clipse
The Following User Says Thank You to e*clipse For This Useful Post:
thingstodo (02-25-2016)
