Old 02-29-2016, 03:41 PM   #363 (permalink)
freebeard
Thanks! 37 views at this time. Sounds like you have a production team.
The 'thing' is a flange, that bolts to an axle half-shaft, or axle flange for short. More importantly, is the preferential direction clockwise of counterclockwise? From the resolver side clockwise is forward.
Those two things on the left in your video with the holes pointed up and down? If they were turned over so they face down my life would be so much easier. I may spot-face the bottom side to make two mounting surfaces there.
MPaulHolmes (02-29-2016)
