Old 02-29-2016, 04:49 PM   #364 (permalink)
Astro
Dreamer
Those two things on the left in your video with the holes pointed up and down? If they were turned over so they face down my life would be so much easier. I may spot-face the bottom side to make two mounting surfaces there.
If i understand correctly you want the mounting faces to be on the underside of those protrusions. with the fixing bolts coming up from underneath?
Could you put in an intermediate bracket. A metal bar running across the two existing mounting holes and fixed in place with bolts coming from above and on that metal bar have the mounting holes where the bolts come up from below?
The Following User Says Thank You to Astro For This Useful Post:
freebeard (02-29-2016)
