Old 02-29-2016, 11:28 PM   #365 (permalink)
freebeard
The problem is that the top is clear to the sides for that stock spreader bar, while underneath there are spot faces for washers with ribs (4 total, you can see the side of one) on the sides. It could be as simple as a tubular Y with threads in the ends of the fork, or two tubes on a plate. This could attach to the stock Beetle transmission mount directly below there.
