Old 03-01-2016, 09:38 AM   #367 (permalink)
Astro
Dreamer
The problem is that the top is clear to the sides for that stock spreader bar, while underneath there are spot faces for washers with ribs (4 total, you can see the side of one) on the sides. It could be as simple as a tubular Y with threads in the ends of the fork, or two tubes on a plate. This could attach to the stock Beetle transmission mount directly below there.
It is a bit difficult to visualise.
Please forgive my lame drawing. It's late here and all i have on this PC is a MS Paint clone.
Could you put a rectangular piece of plate on top of the two mounting points on the MGR overlapping at the sides and front. Then add a similar rectangular plate on the VW trans mount then box in the forward facing side and the two sides.
