Old 03-01-2016, 10:44 AM   #2597 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
It does voltage monitoring
That's the voltage of the pack, right?
one of those resolver circuits right on board
Integration - woohoo!
The main thing about it is, it's all one sided surface mount, so that it can be put together faster.
Or by people that are less co-ordinated
I also ordered some boards that basically step the high voltage down to 0-3v or 4v, or whatever you want it to be. Then the main board isolates the 0-3v using a linear optocoupler, and makes a 0-3v output. That board also acts like a bleeder resistor for the bus cap(s), and also contains a 450vDC 10amp precharge relay (the same one Tesla uses!!).
More integration! How do you tell when the pre-charge is done? To keep it flexible .. can you use .. maybe 80% .. of the pack voltage programmed in the config?
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (03-01-2016)
