Old 03-01-2016, 03:52 PM   #369 (permalink)
jackbauer
jackbauer's Avatar
Paul , that is a thing of beauty Was the rpm limit caused by a preset max frequency or running out of voltage? Am not making as much progress myself. Did get the GS450h transmission mg2 up to 1500rpm which was enough to get the engine driven pump turning fast enough to cover a wall in the workshop in oil!
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
e*clipse (03-03-2016)
