Old 03-01-2016, 04:02 PM   #370 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
That was from running out of voltage. The max frequency does a similar thing, but I had made a mistake on computing the RPM when I was cutting and pasting and rearranging stuff, so the rpm was just zero as far as the microcontroller was concerned. I was being over careful with running out of voltage. I was chopping IdRef and IqRef down too much. It worked a little different than that on the induction motor. This motor needs a bit of a tweek, so when it hits the ceiling, I don't knock them down quite as much. So it's a little, gentle bounce against the voltage disk limit rather than a big bouncy ball. haha.
I'd say going fast enough to get oil to splatter everywhere is progress! I already have the table that it's on, as well as the floor covered in transmission fluid, because I refilled it before screwing back on the holes, and putting back on the round things that spin (freebeard told me the name of those, and now I forgot). The neat thing is, now the motors can just glide across the table, since it's saturated in transmission fluid. So it's easy to swap out motors now. haha
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
e*clipse (03-03-2016)
