Old 03-02-2016, 06:30 PM   #35 (permalink)
duncan
Just a small comment
Frontal area x CD gives drag for a non "streamlined" shape,
There are two types of drag - form drag and skin friction
If you can properly streamline a shape such that the air follows the surface, does not detach and rejoins nicely
Which is nearly impossible in a ground vehicle
Then you eliminate "form drag" and you end up with skin friction which is proportional to the "wetted area" and NOT related to the frontal area
The Following User Says Thank You to duncan For This Useful Post:
aerohead (03-05-2016)
