Originally Posted by WyrTwister
You have a 2 pole 50 amp circuit breaker . You are allowed ( per NEC ) to load that to 80% for continuous duty . So you are correct , 40 amps .
This applies to almost everything .
God bless
Wyr
And as per circuit breaker heat loading, unless you have some sort of cooling going on in your breaker panel, not that I've ever done anything so stupid . . .
At some point I'll get a Model S to plug in and run over everything with the Flir, but with the LEAF the only things that gets warm are the breaker and the contactor
