Old 03-03-2016, 11:08 AM   #31 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
P.S.
Don't write off underbody flow as a mess of large-scale turbulence. While there may be a lot of disturbed air near the ground in a breeze, you can also think of the ground plane as a layer of enforced laminar flow at free-stream speed. Your own laminar surface, if present, will be tripped by the front wheel openings, spreading across at 15 deg. You have to use a slight rake to allow for the progressive increase in thickness of the boundary layer.
Laminar flow is what got the Mustangs to Berlin, but it isn't easy. You need almost-shiny or better surfaces of near-optical precision to specific curves, protected from vibration. This is not a realistic goal for an inexperienced builder, but keep it in mind. It isn't hard to get laminar flow on the 1st 10%; it just keeps getting harder to maintain on the way to 70%.
The Following 3 Users Say Thank You to Bicycle Bob For This Useful Post:
aerohead (03-05-2016), freebeard (03-03-2016), stealth (03-03-2016)
