Old 03-03-2016, 03:49 PM   #41 (permalink)
Peter Hill
Originally Posted by samwichse View Post
Pretty much this. Go buy an Insight with a blown engine/crapped out CVT and a dead hybrid battery. Stick your electric bits in. Go.
But you can do it with so much more style by getting a RX-7 FD and they blow engines daily. Also gives more flexibility in transmission.
Cooling system is responsible for 5-10% of vehicle drag. Rule of thumb, input energy is equally split between wheels, exhaust and coolant. As you will be blanking off a 250bhp cooling system instead of 67bhp it will be near to 10% of total drag while the Honda will be around 5%.
RX-7 FD (base) 90% of 0.518 = 0.466 mē.
Honda Insight 95% of 0.474 = 0.45 mē.
Not cashed in rear wheel spats or disc wheels.
Is it worth it when you will be seen in a Honda Insight?
Originally Posted by renault_megane_dci View Post
I'm interested in that question too but more thinking along the lines of :
Would it be plain stupid to add a perfectly shaped roof addition in order to get a better angle at the back ?
Thanks in advance.
A slant back is nearly as bad as a notch back. All modern hatchbacks although fully conforming to the definition of a Kamm tail have a spoiler that extends the roof line a long way past the hatch to make a recessed transom that is required for a Camm tail.
