Old 03-04-2016, 02:44 PM   #377 (permalink)
freebeard
- [f]reebeard: I would recommend NOT spot-facing the backs of those mounting holes. That will most likely result in a stress-riser, leading to fatigue failure.
I ordered the mounting bolts and they are at the Toyota parts counter for me to pick up. I also got a $67.87 price quote to replace the rear mount rubber puck, mine is sort of beat.
My example is up-river so I can't look at it right now. Are those front mounts threaded in the aluminum? Because the parts diagram doesn't show a nut on a through-bolt.
Do you have a solution for the VW Group CV joint on the Toyota axle flange?
e*clipse (03-04-2016)
