Old 03-05-2016, 01:41 AM   #380 (permalink)
freebeard
I got the bolts as samples, the next step is finding shorter ones in the same grade. The marking on the recessed head is two dots 120° apart. I guess I'm reconciled to a small box that fits the mounts like a hood made from 1/4" plate. Then that bolts to the stock transmission mount. In the back maybe I can cut a section out of that subframe I have no other use for. If I get luck I can just rotate it 90° and drill some holes for the bolts in the end of the frame horns.
If you need four and I need two, that's a half dozen. Would a run of ten be no more expensive?
