I've thought about the same for my Baja Beetle. I figured to start with a 6- or 8-point roll cage and make the battery box a brace inside that. Steel angle on the tubes holding a basalt fiber box because it's an electric insulator.
Are the 'holes' in the roll cage small enough that the smallest battery won't fit through?
Basalt fiber box - I don't think I've seen or dealt with Basalt fiber.
I'm using the 3 racks, or cages .. I think racks are a better term .. that came with the better place pack. As you know, 16 cells fit together with beefier end caps, and 4 threaded rods strung through the whole stack.. 3 of those side by side. Rigid styrofoam insulation on the bottom and sides. I need something translucent and insulating for the top .. not sure what as yet ...
On top of what-ever-that-is .. aluminum tubes across and front to back.
