Old 03-08-2016, 11:46 PM   #122 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
It looks like you will be sealing together aluminum, steel and wood. What do you think of two layers of burlap in Rhinoliner as an undercoat?
I recognize Rhinoliner as a spray-in box liner.
Burlap - as in the burlap used to make potato sacks? Is that a structure for the Rhinoliner to build up, maybe that flexes a bit and allows for movement between the surfaces?
How would I keep the burlap in place? Rivets .. screws .. over-sized staples .. glue? Perhaps one layer of Rhinoliner, then the burlap, then liner, then burlap?
This sounds interesting!
