The fiberglass epoxy showed up, but I had been too busy to use it. Finally yesterday I carved out an hour or so and finished the first layer of fiberglass on top of the shell. I ordered a small digital kitchen scale, which worked out really good for mixing the epoxy at the right ratio, way easier than using measuring cups.
My plan is to flip the shell over and do one layer on the underside. Then I will flip the shell back upright and do another two or so layers on the topside. Then the shell should be ready for surface prep and paint.
