Old 03-10-2016, 12:09 PM   #2614 (permalink)
shaggythegangsta
Originally Posted by e*clipse View Post
Hello Shaggy! Welcome to the project. As far as I know, it's far from closed - Paul & thingstodo have been making incredible progress.
Regarding your questions about a 6010 board, perhaps I'll take a stab at this. I can certainly appreciate your enthusiasm, and more input is always helpful.
I guess I would like to know your goals with regards to your project. Do you want a sensorless controller, like the an1162 is about? What type of motor do you want to control? These two questions radically affect the code. Code will include assembly language if timing is critial or the code needs to be as efficient as possible. Paul's code includes some assembly and I think it's WAAAAAAAYYYYYY better code than those app-notes use. Also, the code used for controlling an induction motor is much more complicated than the code for a synchronous motor like a BLDC motor.
The challenge with embedded computing is that the software and hardware are very inter-related. With any microcontroller, each pin has multiple uses, which affect the code. Paul's board design, for example, is highly developed for the job of running a 3 phase motor using field oriented code. That integration is very beneficial from both a cost and EMI perspective.
It looks to me like the board design you posted is a very multi-purpose demo board. It includes multiple ways of obtaining position feedback, configuration jumpers, and general purpose I/O connectors. To make a motor controller, you would still need IGBT drivers, current sensors, and hopefully some hardware fault-detection circuits. Believe it or not, that is the expensive stuff.
If you're learning about this stuff, I would HIGHLY recommend getting familiar with C and maybe assembly by doing some much simpler projects first. 3 phase motor controller requires critical timing of AtoD conversions among other things. If you're unfamiliar with PWM and taking analog measurements, I would start there - controlling a DC motor. This can be done with a DSPIC30F2010. Another thing you might consider is getting one of Paul's boards. He's run both induction and BLDC motors using FOC on this board, with both encoders and sensorless code.
I hope this helps,
E*clipse
hello e*clipse,
first of all thanks for answering,
my main goal is to make an inverter for induction motor in open loop and closed loop, for my final exam project,
because we don't study c language in my school, my goal was to find an working code, easy to understand and easy to explian, first i found 1162 appnote and until now i was studying that app note.
but then i found paul's inverter and code that is very easy to understand in confront of microchip's code.
my problem was that i have already 10 pcb boards that i have made. and i would like to adapt my board to this code.
my Board is working well with V/Hz mode, also current feedbacks are good.
my board has:
2 current sensors : LEM LTS25-NP (or 3 current sensors and 1 pot)
2 Pot inputs
1 pwm output, driven by a buffer ic
1 fault input
1 fault clearing output.
1 lcd output connector
1 CAN output
1 Encoder input (Filtred)
4 buttons
4 leds
The Following User Says Thank You to shaggythegangsta For This Useful Post:
e*clipse (03-11-2016)
