Old 03-10-2016, 10:14 PM   #11 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
I second dumping the slush box and putting in a junkyard manual. Where will you tag this? We can't do much to the engine and still pass California smog's visual component.
I'd chase aeromods because although the engine may be an issue, you can't fail the smog test for an airdam.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
