Originally Posted by tajman
Is this the design that includes the integrated (software selectable) resolver to encoder? I'm not afraid of solder or solder paste  The PCB and SCH files I have are from 2014 - from the OpenRevolt wiki.
The resolver to encoder circuit is on the same board. I don't remember if it is software selectable - you've just read through everything so you probably know more than me at this point.
The resistor dimensions and pads are small. Past reading glasses for me. We're into the lighted magnifier range. A tiny dab of paste is put on each pad with a syringe, then the parts placed on top and the paste kinda sticks it there until you put it in the toaster oven to do the soldering.
The single-sided board was just completed ... Mar 1? The boards are here now.
