Old 03-11-2016, 08:08 PM   #6 (permalink)
ChopStix
Primer is still paint!
ChopStix's Avatar
90 day: 32.46 mpg (US)
Originally Posted by Striker2237 View Post
Looking to convert to an E fan for space savings and hopefully one or two more mpg if I'm lucky.
Can someone point me in a direction to start? I would like to have enough cooling ability to keep the engine at 180 degrees at idle in summer. Manual switch would be nice if possible. Thanks!
I bought my E fan conversion off ebay for $51 USD. The 16 inch fan was $26 w/free shipping and the thermostat was $25 w/free shipping. The thermostat is temp adjustable. So all you do is throw it on the vehicle and dial it in to turn on/off at whatever temp setting you set. Then you can wire a switch to manually turn it on/off if you choose.
My plan is slightly different than what you said. I'm considering adding a second fan in front of my radiator with only a manual switch for when I pull my trailer with the AC on. In that situation I would just leave it on the whole time. But the main fan behind the radiator will only be run automatically switched by the thermostat, no manual switch.
Here's my build thread for my van
