Old 03-11-2016, 10:29 PM   #17 (permalink)
oil pan 4
If you have the stock fuel system then you have the carter thermoquad carb.
I am used to old dodges with the thermoquad run so rich they roll coal.
Why not swap it out for something you can tune like an edelbrock 650, advanced tuning kit and an air/fuel ratio meter?
When a lifted up ram charger with 318, 4.1 gear and 727 transmission can get 12 to 13mpg by some one obsessed with keeping everything stock, to include the junk thermoquad carb you should be able to do a lot better than 7mpg.
If you want better fuel mileage there really isn't any point in modifying anything until you get it running correctly.
