Thread: New Car Buyers
Old 03-12-2016, 12:13 AM   #32 (permalink)
MobilOne
The two times that I worked in auto plants (1960's), I do not remember the amount of options to be a problem. There would occasionally be an option that would be hard to fit, but usually there was a trick to installing it. If you knew the trick, then easy peasy, otherwise it was a b####. Remember though, those cars were designed on paper, using pencils, pens, slide rules, T-squares and drafting tables. So those cars were pretty simple in comparison to todays cars. All you need to work on those cars are normal tools and/or a gas wrench.
