none - '98 Honda Civic HX none - '00 Chevy (Geo) Metro base none - '00 Saturn SL1 base
Originally Posted by serialk11r
Are you sure it's detonation at 18:1? If it's a popping sound, that's probably misfiring not detonation. Detonation above 16:1 is very unlikely because you have a lower flame temperature.
I've written about my experiences doing this on my Scion FR-S (a Subie FA20 motor). It doesn't like idling at 17:1 no matter what, and doesn't let you tweak cam timing at idle to reduce EGR. Lean burn only works when the engine is able to consistently burn the mix quickly.
good post
