Old 03-12-2016, 02:35 PM   #5 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by ever_green View Post
For my car I have programmed the ECU to set 16.2:1 AFR as lambda 1.0. this means every time it's targeting 14.7 afr it's actually doing 16.2. I have confirmed this with wideband. Ignition timing wise i could not add much more than 2-4 degrees depending on load/throttle before onset of knock. I also experimented with going leaner to 18:1 but I experienced minor (but persistent) knocking or detonation at cruise. So is it worth going any leaner at the cost of ignition timing? So far consumption for last 1000 kilometers have improved by 9% with 16.5:1 AFR.
So is it worth going any leaner at the cost of ignition timing? Usually not because a leaner A/F ratio will require more ignition advance because of a slower flame speed. If you decrease your ignition advance this will increase your BSFC and hurt FE.
Pressure Gradient Force
The Positive Side of the Number Line
