Old 03-12-2016, 04:24 PM   #89 (permalink)
Bill the Engineer
Bill the Engineer's Avatar
Anyway, do you expect the electronics and interfaces integration to be harder than the bodywork?
If I stay with the Prius V speedometer and adapt it to the Firebird dash with some fancy cut-and-paste, the electronics and electricals will not be that bad. If I try to adapt the Lexus speedometer, things get more complicated. Either way I will mostly be making extension cables here and there.
For instance, the wiring will be there for the center brake light. Adapting a side marker assembly from a '69 Firebird in place of the gas door emblem makes a great center brake light assembly.
Bill the Engineer
The Following 4 Users Say Thank You to Bill the Engineer For This Useful Post:
bespurcell (04-10-2016), Daschicken (03-14-2016), gasstingy (03-30-2016), mcrews (03-12-2016)
