Originally Posted by thingstodo
I don't remember if it is software selectable
Maybe "software selectable" isn't the right term but I'm referring to this post by Paul:
Originally Posted by MPaulHolmes
Here's one of the new boards I ordered:
It's not here yet though. It does voltage monitoring, and has one of those resolver circuits right on board. You can also turn the resolver circuit off with the chip select pin on the resolver chip, so you can use the board to power something with a resolver, and then another motor that uses an encoder. The main thing about it is, it's all one sided surface mount, so that it can be put together faster.
