Old 03-13-2016, 01:14 PM   #28 (permalink)
freebeard
EMP depends on the gross dimensions of the object, powerlines (and anything attached to them) are most vulnerable. On the other end of the scale, transistors are more vulnerable than vacuum tubes.
A gas engine with a magneto is probably equivalent to a diesel.
Faraday cages can pass air, but openings or hatches need grounding contacts along the edges so they seal electrically.
