Build log for my DC controller
Prior to March 9
Paul got the DC controller boards built (or mostly built) before I arrived.
The boards were already designed. I think he got a couple more made. And ordered the IGBTs. And everything else. Received, solder paste put on, parts placed, and board soldered in the toaster oven.
The copper sheets for the capacitors were purchased, cut, marked out and a template made.
The chill plates were ordered as 3/4 inch thick 6061 aluminum plate, cut to size, the cooling channels were machined, the mounting holes drilled and tapped, mounting hardware ordered and received.
One set of cooling holes were drilled and tapped. Plumbing hardware was received.
And a *WHOLE BUNCH* of other stuff that I don't even know about!
