Originally Posted by Ecky
You can find the details in the build thread linked in my signature. Start on page 8:
http://ecomodder.com/forum/showthrea...d-29288-8.html
You'll be building a trickle charger, but it needs to be able to provide at least 180v DC @ 350ma or less, and you'll also want to power the 12v cooling fan for the battery while you're doing this.
The units available on eBay sometimes have the ability to discharge your battery and then charge it to full, which gives a slightly more thorough balance, but you can do that yourself with an incandescent lightbulb, and I don't think it's helpful or even good for a battery that isn't on its last legs.
Is there anywhere that i can buy the cells for the battery separate from buying a whole battery? If i test all the cells and find a few that are bad where can i buy new cells? Thanks!!!!!!!!!!!!!!!!!
