Well - it ain't all as shiny as it seems.
From that link:
Electricity generated at the Yokohama City Wind Power Plant (Hama Wing) will be used to electrolyze hydrogen that is compressed, stored, and then transported in a hydrogen fueling truck to four sites: a factory, a vegetable and fruit market, and two warehouses. At these locations, the hydrogen will be used in fuel cells to power forklifts operating in diverse conditions.
This low-carbon hydrogen supply chain is expected to reduce CO2 emissions by at least 80 percent compared with a supply chain using forklifts powered by gasoline or grid electricity.
Using hydrogen generated by windmill electricity generates less CO
2 than using electricity straight from the grid.
Who could have guessed.
A bogus comparison means deliberate disinformation. It should make all the signs flare red.
The forklifts are compared to lead acid battery forklifts, which have a similar operating time but take 6 to 8 hours to charge.
Lithium iron phosphate battery forklifts would be lighter, last longer, charge faster, but also be more expensive than their lead acid counterparts.
I bet they'd still be cheaper than the hydrogen ones.
So, Toyota. Run your comparison to windmill fed LiFePO4 battery forklifts for a change.
