Do you have to buy the control arm to get the bushing?
If so then get an acetylene torch. If the torch is not available a grinder. Cut the outer bearing surface (of the bushing) of the control arm away or burn it off with the torch. Once that is done you can heat the collar and drive the bolt out for reuse, or just replace it and cut it away.
regards
mech
