Originally Posted by MPaulHolmes
They may have different settings for initializing the quadrature encoder interface. Or maybe that's not the problem at all. I don't know why it's not working with my code. Maybe there's an issue with the swap ab inputs, or something. YOu coudl try to change:
QEICONbits.SWPAB = 0; // don't swap QEA and QEB inputs.
Change that to SWPAB = 1 instead?
i just removed the pull down resistors and now i have 4.16V max
i also tried to swap the inputs but the postcount is remaing the same
this is configuration code of an1162:
Code:
// ============= Encoder ===============
MAXCNT = MotorParm.iCntsPerRev;
POSCNT = 0;
QEICON = 0;
QEICONbits.QEIM = 7; // x4 reset by MAXCNT pulse
QEICONbits.POSRES = 0; // Don't allow Index pulse to reset counter
QEICONbits.SWPAB = 1; // direction
DFLTCON = 0; // Digital filter set to off
i also tried to disable the filter but nothing changes..
