Old 03-19-2016, 01:25 AM   #31 (permalink)
Isaac Zackary
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
I don't know why a generator would not charge a leaf.
It may just be Nissan doing the legal CYA thing.
I didn't know that the leaf could not be generator charged, all the more reason to build my own EV when I decide I need one.
It might just be for safety reasons. From what I've read the ground on a generator is wired differently (or not at all) than it is on a home. So when the Leaf tests the line for ground, which it does before allowing a charge, it sees that ground isn't ground and aborts charging. So in order to use a generator (I've only seen where the Honda electronic sine wave EU2000's are being used) on a Leaf, they have to add a resistor between ground and neutral. And another between ground and hot. That way the Leaf thinks it's grounded and allows charging.
I had thought of building my own EV until I saw the prices of used Leafs. You're not going to be able to build a 24kW-h EV for $7,000. At least I don't think you can, and especially not with air conditioning and heat-pump heaters and heated seats, front, back and heated wheel.
