You said you have a carb rebuild kit, you can do the work with the carb on the car and most of the vacuum hoses left in place, I'd repair or replace the base gasket at the same time.
The accelerator pump wears out over time and leaks, so a rebuild might fix multiple problems you didn't know about.
